Wind River corrupt media?
I am having difficulty installing wind river on our classmate PC.
I reimaged, then started following the wind river installation instructions.
(I did not start Wind River after the installation of disc 1)
When I start setup on disc 2, I get the error: "This media is corrupt: See “setup.log” …
In the setup.log, it shows some files that cannot be accessed:
…/images/CDR-R158490.1-2-00
…/images/CDR-R158491.1-2-00
and 7 others.
On my disc 2, I have a set of directories are called:
…/images/cdr_r158.1_2
…/images/cdr_r148.1_1
etc.
I do not have a USB drive, so I am copying the contents from the DVD on my Ubuntu Linux machine. I do not have access to a windows machine here.
I can understand that the file name case might be changed, but the names should not change… Except now I notice that the filenames I see are in 8.3 format.
Would it work to rename the directories that I have to the ones that it says it is missing?
I think there is a lot more that is cut off… I have a directory called “installe” not “installer” so I don’t think this is going to work.
Anyone else have this trouble? Find a way around it?
