Our programming team has been working for about the past week on getting our 2go pc verified for genuine windows. After reading several blogs and forum posts we currently know that the .bat file is only a temporary fix but also that is does not work. If anyone knows how to fix this or can tell us how they sucessfully did this it would be greatly appreciated.
p.s. im a newbie so any and all advice is appreciated
If you connect to the internet it should be fixed⌠Or, if not, Iâm not really sure what I did. I am no longer seeing the message and am considered verified.
Either way, I donât believe Win7 has a âreduced functionalityâ mode. At the worst, youâd have to put up with some popups.
I assume the batch file does this, but enter âslmgr -rearmâ at the command prompt.
you can rearm it up to 3 times I do belive and at that point you need to either clean install it and go it again for 90 day block or get the actual software.
If FIRST doesnât get us a fix by the time competition begins, then Iâd suggest doing a clean install/activate at the beginning of March before our first event.
Nothing like having your driver station die in the middle of a competition day and having to re-image without Internet access. â what time is our next match???
[quote=âNothing like having your driver station die in the middle of a competition day and having to re-image without Internet access. [Iâ]
â what time is our next match???[/quote]
