WindRiver Won't deploy
it’s stuck in here
http://up368.siz.co.il/up2/kfu5gozy0wyq.png](http://www.siz.co.il/)
We’ll need a bit more information to know the trouble. Here’s a few things…it appears you are from FRC team 1943. Is this true?
  1. open a command prompt windows-R and run the ‘cmd’ command. At the command prompt, try ‘ping 10.19.43.2’ when you are connected via ethernet cable to the robot. If you do NOT get replies from the ping, then you have an IP address issue. We can address that as you give some responses…
  2. If your ping worked, then your cRio is ok…so the more likely cause is that the “FIRST downloader/deployer” is not configured. In Windriver Workbench, go to Window->Preferences… and click on the FIRST Downloader item. You’ll find a ‘team number’ there. Set it to your team number and then browse to your project directory/PPC603gnu/Debug/… and find the ‘.out’ file down in those directories - this is the file that needs to be downloaded.
Let us know this part and we’ll start from there…
bob
