Well, we have constantly been having trouble with the Dlink DAP-1522 provided by FIRST. It is one of those things where it seems to work when it wants to type of thing, however if we manually set an IP Address on Windows, it seems to work fine. The DHCP Server has been enabled on the bridge, yet we are constantly having trouble with it. Anyone else had trouble with it?
Actually, you don’t want to be using the DHCP server. The control system is meant to be used with static IPs.
The bridge should be:
IP: 10.te.am.2
subnet: 255.0.0.0
no gateway
How and for what are you using DHCP?
It’s okay for a programming laptop, but as Phil alluded to, not the Driver Station.
