The Default Gateway for your PC should be the address of the D-Link Access Point (10.2.23.1). Since the subnet mask puts the cRIO (10.2.23.2) on the same subnet, however, the Default Gateway will not matter.
One thing, setting up bride, asked for Pre-shae key, put what was in instructions, change team name: 0223WPAKEY – not sure if leading ‘0’ needed
Your SSID should be set to “223” with no leading zero. If you are using wireless security, the key can be whatever you want it to be, as long as you enter that key on every device that needs to connect to the DAP.
And just to make sure everyone is on the same page, I’m referring to pages 6-9 of the How to Configure Your Radio guide. The DAP-1522 will be put in Access Point mode, not in Bridge mode.
