wiring a keyang
I tried searching, but im having trouble figuring out how to wire the keyang thats connector is not provided in the kit
do u guys just soder on a connection?
thanks for the help
In the bag with all the crimp fasteners, there should be 4 silver connectors. these and the two small black plastic housings get put together to form a connector, which wires can then be connected to.
(look on the bottom of page 12 of the KOP checklist to see what I’m talking about)
Look on page 12 of the KOP document. They are supplied to you there.
http://www.usfirst.org/uploadedFiles/Community/FRC/FRC_Documents_and_Updates/2008_Assets/Manual/2008%20KoP%20Checklist-RevB.pdf
alright thanks a bunch! can I also use those on a nippo-denso motor?
I haven’t ever used the Denso motor, but I imagine it would work.
Edit: according to the tips, guidelines, and good practices section of the manual, you can order a matching part, but small slide-on crimp connectors will work as well.
does anyone know where to get replacements. Need them very badly.
I think these might work:
2-Pin Battery Connector Pack - Mates to the Mini RC
not 100% sure though
