Wiring AMT10 series encoders to SRX Breakout?
Hi all,
We’ve tried to wire the AMT10 series encoders by CUI, which were provided in FIRST choice this year.
http://www.cui.com/product/resource/amt10-v.pdf
It seems that there are three signal channels:
A, B, and X (Index)
From my understanding, Channel A and B can be used independently if you just want RPM, and not direction. A and B together allow for direction and RPM, as B is out of phase from A. While Index serves as a reference for A and B, and is used as “verification.”
Since the SRX Encoder breakout board (http://www.vexrobotics.com/217-4398.html)
does not have X as an input, would it be okay to forgo the Index, and just use channel A and B.
The application is to determine RPM for mecanum drive,
Would it be better/easier to just use roboRIO wiring for this?
Thanks!
You can ignore the index line for your purposes.
It just gives one tick per full revolution as a reference point if desired. A home point if you will.
A/B/+/gnd
Ah, I suspected as much.
I will confirm tomorrow with an O-Scope.
Thanks for the quick reply.
