In order to wire an analog sensor to the drivers station, in this case a potentiometer, do I need any type of resister between the sensor and the drivers station.
Thank you for any help you can provide,
DavidB
DavidB
A pot is a variable resistor, so no you do not need another resistor as part of the wiring.
+5v to one end, ground to the other end, and signal to the wiper.
Thank you for the help.
