Wiring Double Solenoids (Nitra Pneumatics)
We got this double solenoid valve from automation direct, but we can’t figure out how to attach wires to them.
Here’s a picture:
Thank you!
Sorry the image didn’t work, hopefully it works this time:
https://www.automationdirect.com/images/overviews/300xNxnitra_solenoid_valve_avs53_400.jpg.pagespeed.ic._GGvsZ5fId.webp
Perhaps just the model number.
For spam reasons new user are restricted from posing images and such, until they’ve posted awhile.
They are the NITRA Pneumatic AVS-5 Series Air Solenoid Valves. 5 port, 3 position, double acting.
Thanks!
loosen the screw on the connector cover, lift off the housing, see what you have. Does it look like one of these?
Each connector end (one end on a single, two on a double solenoid) should get two solenoid connects (a positive and a negative-I think they are marked 1 & 2). The connector also has a ground terminal that you can ignore-it isn’t used.
The pair of connector wires then go to one of the PCM solenoid ports.
