Does anyone have a way of doing this? A few members of my team tried to splice the adapter (not sure if that’s the right term), and well, either the bridge is fried, or the adapter for it is fried.
Any suggestions would be very much appreciated, especially with the lack of time.
make sure you connect the right wire to the + and - terminals. the manual states that the striped wire (has white marks on it) is the positive lead. it sounds as if you may have switched them by accident.
Okay, I got the connector and what not. How exactly do you get the wires in it? I know which goes where, but I wasn’t watching anyone doing this. I was waiting for it to be done so I could test the programming, seeing as they did this without my knowledge before I could do any testing.
Its a wego connector. Use the wego tool or a small screwdriver to open the connector and insert the stripped wire. You are connecting the wireless bridge power to the 12 volt connector on the power distribution board right?
Brian
