wiring
I got the new inventor that FIRST gave out and started to see what is new and what changed and what stayed the same. well i saw you can add pipes and wire to your files. but the only problem is how to add wires and pipes to your files? cause the book is not in there.
Go to the website below. There is a nice tutorial on using cable and harness in IV8 Pro. http://www.lns.cornell.edu/~draft/Manuals/Inventor8_Cable_and_Harness_Getting_Started.pdf
It is quite easy to use if your computer doesn’t have XP service pack 2 installed. If you are not so lucky go to the autodesk discussion groups http://discussion.autodesk.com/thread.jspa?threadID=375732for the work around. Good Luck.
I am using Inventor 9 Pro, and i for the life of me i can’t find the wire and harness tools, I know Inventor clams to have them but i cannot find them, is there an add on that must be downloaded or bought?
