World Rankings 2014
I calculated the rankings of all teams using the FRC District Standard Points Ranking System as shown below. Since everyone does not have a standardized 2 events per team or 12 matches per event, I made the following modifications: Win points are normalized based on 12 matches per event. The first two events are counted. If a team has participated in less then 2 events, their first event is doubled (as a result, every team has their points doubled this week).
POINT CATEGORY POINTS 					POINTS
Win-Loss Record in Qualifying Rounds
Win 							2
Tie 							1
Loss							0
Alliance Selection Results
Alliance Captain				        Equal to 17 minus the Alliance Captain Number [e.g.: 14 points for Alliance #3 Captain]
Draft Order by Acceptance  				Equal to 17 minus the Draft Order Acceptance Number [e.g.: 12 points for the Team that is 5 th to accept an offer of Alliance]
Elimination Round Performance 				5 points for every match won in which a Team ’s robot participated,
Awards
Chairman’s Award				        10 Points for
Engineering Inspiration and Rookie All Star Awards      8 Points
all other judged Team awards				5 points
Team Age
Rookie Teams 						10
Second-year Teams 					5
Here are the top 25. Full rankings are attached. The full rankings show all factors, as well as the rankings without normalizing for matches or number of events.
Rank	Team	Events	Points
1	624	1	170
2	33	1	156
3	1310	1	152
4	1986	1	152
5	399	1	152
6	3824	1	150
7	118	1	150
8	138	1	150
9	1678	1	150
10	525	1	146
11	2590	1	142
12	2046	1	142
13	610	1	140
14	2907	1	140
15	75	1	140
16	107	1	138
17	1261	1	130
18	177	1	126
19	3393	1	126
20	1403	1	126
21	341	1	124
22	2468	1	124
23	294	1	120
24	2557	1	118
25	1241	1	118
I have compared the results with the FiM, MAR, and PNW rankings, and they agree. I used Ed Law’s standings for Centerline.
WorldRankings2014_wk1.0.xlsx (70.9 KB)
Since this system may be instituted for all District events in the future, it’s worth discussing this calculation. Several thoughts:
  • Since this is a World Ranking (which has no real consequence) vs District qualifying (which needs to have clear, fair and balanced rules), I think you should use the LAST 2 events to reflect how a team evolves during the season and best reflects how they are doing going into the Champs. (I understand why Districts uses the first 2 events and agree with that.)
  • Losses in elimination rounds should count against a team, say -1.
  • Also, later wins should gain more wait, beyond simply 5 more points. This will give a bigger distinction for teams that make it to the finals, more than just 5 more points. Winning an overall event should be worth much more than winning 100% of the matches (e.g. 24 points for going 12-0 vs 30 points for winning the Regional.) Probably should aim for winning the regional to be worth 48 points instead (double winning the qualifying rounds). Scoring 6 points for quarters, 8 points for semis and 10 points for finals would do that.
  • Finally, you should normalize on a non-integer basis as a percentage. It’s more difficult to win more matches in a longer tourney because of the abuse of the robots, but the current scaling doesn’t give full credit for that.
You have the MAR rankings? They are not on the MAR site that I can find.
In the spreadsheet, if you add the district name, a sort on this should be equivalent to the source rankings, no?
EDIT: I found them in MAR forum thanks. I don’t know why they didn’t come up in my search…
Thanks for this Joe.
I watched Team 75 play (and win) this weekend, and they were astounding. It is right they are ranked so highly…I think this may be another great year for them. And the nice thing is, they bring their own crowd…:smiley:
Thank you Don for your nice comments! It was nice having your team as an addition to our stands as well. Congrats again on Chairmans!
If I was trying to do rankings that reflected teams going into champs, I would not be using anything close to this system. Instead, this is a way for teams not in districts to see how they stack up. The word rankings is simply because that is what Michigan uses.
Normalization on non-integer basis has the effect of number of matches acting as the first sorting criteria. When I first starting playing with California rankings last year, I did play around with integer and non-integer normalization (as well as no normalization). I was much happier with integer normalization.
These are probably better discussed either at http://www.chiefdelphi.com/forums/showthread.php?t=121132 or http://www.chiefdelphi.com/forums/showthread.php?t=121362
Joe,
Do you plan to release Week 2’s Results?
Thanks for putting this together.
-Clinton-
Just checking to make sure I followed what Joe Did
So I really want to Normalize for number of events played, and for the size of certain events. Its not fair to compare a smaller, 30 team district with a with a 42 team district with a 58 team 3 day regional.
My idea: separate out these different categories as appropriate. Qualification wins is pretty self explanatory, it should normalize for the number of chance you have for a win. The middle section of the formula should be adjusted for the number of times you get to be picked, judged and play in eliminations. The last section should only be awarded once per season before district champs, I’m open to suggestions, especially for the last segment of the formula.
My Proposed Formula, point values follow District Standard Points Ranking, hopefully it lines up with Joe’s.
Normalized World Rankings=
(Qualification Wins + Qualification Ties) / (Qualification Matches Played)]
(Alliance Captains + Draft Order Acceptance + Elimination Performance + Judged Awards) / (Number of Events Participated In)]
[Team Age + Chairman’s + Engineering Inspiration + Rookie All Star]
[LEFT]Edit: I completely realize this makes it really difficult to figure out ties. Probably should just prioritize the second part of the formula.
[/LEFT]
Yes, I’m error checking and formatting the results.
It’s close to what I do.
Round((Qualification Wins + Qualification Ties) of first 2 events) / (Qualification Matches Played in first 2 events) ** 24*]
(Alliance Captains + Draft Order Acceptance + Elimination Performance + Judged Awards) *of first 2 events / Min(Number of Events Participated In,2)2]
[Team Age + (Chairman’s + Engineering Inspiration + Rookie All Star) [i]of first 2 events]
Here are the top 25 after week 2. I’ve attached the full spreadsheet.
1	624	1	170
2	4488	1	161
3	33	1	156
4	2175	1	156
5	1817	1	156
6	4967	1	156
7	1310	1	152
8	2337	1	152
9	1986	1	152
10	399	1	152
11	3824	1	150
12	118	1	150
13	138	1	150
14	1678	1	150
15	1108	1	150
16	525	1	146
17	254	1	146
18	16	1	146
19	3467	1	144
20	4911	1	144
21	2590	1	142
22	2471	1	142
23	2046	1	142
24	1266	1	142
25	2468	2	141
```<br><br><a class='attachment' href='/uploads/default/original/3X/a/8/a8158f865c8b8a8a694b9e322bb6d5191281bbd9.xlsx'>WorldRankings2014_wk2.2.xlsx</a> (185 KB)<br><br><br><a class='attachment' href='/uploads/default/original/3X/a/8/a8158f865c8b8a8a694b9e322bb6d5191281bbd9.xlsx'>WorldRankings2014_wk2.2.xlsx</a> (185 KB)<br>
It makes me happy seeing a second year team in 2nd place.
Wow top 20 after some teams we look up to every year!
So this is better described as “World District Scoring” rather than “Ranking” since it’s not really relevant to non-District teams?
Wow tied for third, I didn’t think I’d ever see my team so high on some type of FIRST wide ranking. :slight_smile:
It is really cool to see our team number on that list in our rookie season!
I am doing something similar to score the Ohio teams for our State Event this year. Question on your week 2 results. 4269 came into Q3-3 as a back up bot at Crossroads, won 5 matches, why do they not have any elimination points?
I have to correct backup teams points manually. I remember doing that for 5188 and 4269, but probably overwrote those values when fixing something else. Attached are corrected rankings.
WorldRankings2014_wk2.3.xlsx (166 KB)
Thanks!
There are a few issues with week 3 events. St. Louis only posted a few awards. I don’t have correct alliance selection results for Mexico City. The order posted in the 2014 Alliance Selection thread was not correct. When first and second pick could not be unambiguously determined, I used the higher seed as the first pick. I will update when updated data is available.
Week 3 rankings are attached. Top 25 are below.
1	4488	1	161
2	33	1	156
3	2175	1	156
4	4967	1	156
5	1310	1	152
6	2337	1	152
7	118	2	150
8	3824	1	150
9	971	1	150
10	138	1	150
11	1108	1	150
12	1986	2	149
13	1678	2	148
14	4125	1	148
15	525	1	146
16	254	1	146
17	16	1	146
18	107	2	144
19	3794	1	144
20	2996	1	144
21	3467	1	144
22	4911	1	144
23	1126	1	142
24	67	1	142
25	2590	1	142
```<br><br><a class='attachment' href='/uploads/default/original/3X/2/4/24e08e5adf3548862374b7e35e476be73efc68d8.xlsx'>WorldRankings2014_wk3.1.xlsx</a> (243 KB)<br><br><br><a class='attachment' href='/uploads/default/original/3X/2/4/24e08e5adf3548862374b7e35e476be73efc68d8.xlsx'>WorldRankings2014_wk3.1.xlsx</a> (243 KB)<br>
I’m currious is this just for week 3? because 2590 competed in week 1 and 148 not on this list?
