Worm Gears
Hey,
I’ve got a project that requires a worm gear. I need to test a bunch of different gears and am looking for sources to buy. So far I have only found
http://www.robotobjects.com/scripts/prodList.asp?idCategory=39#worm-gears
These gears are what I’m looking for… < 1" diameter, 40:1 and 50:1 ratios, plastic. But like I said, I need more gears, slightly different sizes, different ratios, etc. Does anyone know of some online stores that would have what I’m looking for?
Thanks you for your time and sorry if this is in the wrong spot
try www.sdp-si.com
Try Standard Drive Products- Stirling Instruments
McMaster-Carr
Both have pretty large selections of gears.
Links broken. Try: http://sdp-si.com/index.asp
http://bostongear.com/products/open/spur.html#
