would this work?!?
Would this work or burn something out?
Using EasyC:
I have the same setup on both sides of the robot; a pump that heads out/in to lower a ramp on either side (so its actually 2 pumps, 1 on each side of robot)
Could I use the same button to lower each and raise each by doing the following
OIToRelay (3,1,2,1) //jostick on port 3 trigger button forward to relay 2
OIToRelay (3,2,2,2) //joystick on port 3 thumb button reverse to relay 2
OIToRelay (3,1,3,1) //jostick on port 3 trigger button forward to relay 3
OIToRelay (3,2,3,2) //joystick on port 3 thumb button reverse to relay 3
Would it cause problems trying to use the same input to control relay outputs???
I’m not a programmer, but it looks to be fine.
