WPI Java Source Code
So either I am very blind, or it is just not obvious, but I cannot find the WPI source code for Java this year.
I followed several different links but keep getting back to previous seasons. It does not seem to be in the same place anymore.
Does anyone have the link for this years code?
Thanks!
Randy
The plugins are in the same place as last year, but different then years before that. See http://wpilib.screenstepslive.com/s/3120/m/7885/l/79405-installing-the-java-development-tools
Once you install the plugins, the source code is in the same place as previous years. See http://wpilib.screenstepslive.com/s/3120/m/7885/l/79739-building-with-a-custom-version-of-the-wpilib-source-code
OK zip file in the library directory. Will look there.
Is there a source forge / svn / git anywhere that patches are applied?
Thanks!
Randy
They have an SVN repo on FirstForge but it’s way outdated :-(. They only have the C++ library from a few years ago on there but nothing for Java.
Alex Brinister
It is located in the sunspotsdk folder that gets installed with the Netbeans plugin.
~/sunspotfrcsdk/lib/wpilib.src.zip
