Wpi.local help
hey i am a new programmer in the frc and i ran into a problem after watching this video: https://www.youtube.com/watch?v=oa_Z5BYKfMI after while watching that i tired to build a java application using the java example in the site and after running gradlew build it did open a new build file inside the folder but in the video the file looks different and has the most important part of the file which is the java application inside a file inside the new build file named libs but in my case inside build there are only 3 files and all of them are empty can someone help?
i don’t have an actual answer, but @Peter_Johnson who is in the video you shared is a user here. Maybe he may have some insights. Plus he has one of the highest solutions counts on here. As a note, it would be helpful to see the code being used
You can put code between three ` symbols at the start of your code and the end of it to help preserve formatting.
If you could also get screenshots of your build settings and stuff like that it would help us pin it down. Not too much to go on currently
