WPILib Install Failing MacOSX 13.1
I am getting ‘System.Exception: The artifacts file was damaged.’
The X Code tools have been installed
Are you running a ARM based system (M1, M2) or intel based system? Make sure you are installing the correct version for your system archeticture.
Running Intel 8 core (MacBook Pro) and have downloaded the Intel version of the dmg
WPILib_macOS-Intel-2023.1.1.dmg
When I ran the X Code tool install it said they were already installed as I have the previous years WPILib installed.
How many disc images do you have mounted? You should first unmount all existing images and then start over.
That was it! Thanks!
I downloaded the arm version first by accident and it was still mounted.
