[WPILib Meeting Notes] 4-15-2021
Posted on the WPILib Development Blog, 4/15/2021 Meeting Notes:
2022 BREAKING CHANGES
DEV-OPS
DOCUMENTATION
  • Dalton: Fixing RTD’s Sphinx 4 incompatibilities
    • HoverXRef
    • Sphinx-Tabs
  • Joystick article draft is up
  • Dalton: Successful migration from master → main
ROMI
  • Basic custom device support is working
    • REV Color Sensor over I2C
    • this close to getting it sending data over SimDevice
SYSID
  • Tyler: Merged the following
    • Analysis component refactoring (renaming/general cleanup)
    • Data filtering improvements; integration tests have much smaller tolerances now, but acceleration fit test still isn’t great (only affects arm)
    • Moved JSON converter to menu bar and added JSON to CSV export to that menu dropdown too
  • Tyler: Generator PR is still WIP
  • Tyler: Plan to refactor “data” and “filteredData” stuff into “data” for raw data and a pipeline of filtering functions operating on “filteredData”
  • Tyler: dt plot Y range override doesn’t always work. Autofit for Y works every time if that’s enabled.
FRC-CHARACTERIZATION
  • Do we want to update to Python 3.9? (#32)
    • Since sysid exists, it’s not worth the risk of breakage
PATHWEAVER
  • 2 bug PRs to merge before on to 2022
  • Potential issue on unit conversion involving inches as base unit.
SHUFFLEBOARD
  • 2021 networktables and cameraserver artifacts never published (#696)
VS CODE/INSTALLER
  • More asks for a CLI installer tool
WPILIB
  • More discussion on motor controller
  • Starlight working on Mechanism 2D
  • Release soon
