WPILib update caused PID command behavior to change?
Hi all,
We have been battling weirdness between two driver stations for several days now and finally tracked down at least the cause but not an explanation. One hadn’t been updated to the latest WPILib and NI game tools (i.e. one had the Feb 28 update, one hadn’t).
We have a PID controller for a subsystem. The older driver station was being used for tuning it, the newer one was being used for the rest of code development, taking in the PID constants and such. The command code is essentially the same, minus some extra state variables and such on the “real” code vs the tuning prototype code.
We would like the subsystem to hold the position. Unfortunately, there is a constant force spring fighting the hold.
Code on the old driver station would (profiled pid) would hold the subsystem in place after completing the trapezoid profile (occasionally, we would see it reset down, against the upward force of the spring). The new driver station however will not hold its position after completing the
trapezoid profile.
Digging further, for some reason the position command pre-update never finishes. Our isFinished method is just return subsystemController.atGoal(); Adding prints confirmed the older driver station was never finishing and the newer one is.
So two questions -
  1. Did something actually change recently that would influence when atGoal() is reached in a PID controller or am I crazy?
  2. Is there a better way to actually hold at a position (at the end of the trapezoid profile) against an external force than to prevent the command from finishing? I can structure things around that behavior if necessary but it seems very hacky.
I made a repo with our prototyping code - GitHub - South-Doyle-Robotics/PIDholdissue in case we are just doing something dumb. This is our first year doing Java.
The behavior of PIDController changed twice during the season: History for wpimath/src/main/java/edu/wpi/first/math/controller/PIDController.java - wpilibsuite/allwpilib · GitHub
2023.2.1 had this change: [wpimath] Fix PID atSetpoint to not return true prematurely by sciencewhiz · Pull Request #4906 · wpilibsuite/allwpilib · GitHub
2023.3.1 had this change: [wpimath] Make PIDController::Calculate(double, double) update setpoint flag by calcmogul · Pull Request #5021 · wpilibsuite/allwpilib · GitHub
Hmmm, that’s not good.
Is there some good way to have a PID controller hold a position against an external force? I’ve looked around CD and random FRC github repos and not gotten much.
If not, is there an issue with intentionally not finishing our PID controllers for this subsystem? Most of the time they are used with whileTrue() sorts of events. I can add a .withTimeout() maybe in situations where they are not, so code-wise it’s probably not a huge deal. Is it “bad” for other reasons?
I tried a bunch of other workarounds on the new driver station such as fiddling with the default command for the subsystem to continually go to a specific position. This sorta worked, but I had to remove the default command and re-add it when I wanted a different position.
Thanks
We use a PID subsystem based off of this example.
We use commands to set new goals. These commands are instant/non-blocking and the PID subsystem works on “getting the goal done” once enabled, continuously. We reset() the subsytem PID every time a new goal is passed in, but the PID controller is always trying to hit the goal.
Then we have a WaitOnArm() command that blocks by polling the subsystems atGoal(). This way we can have our Arm control be async or synchronously.
Do you have a link to your Github? I am also having trouble with using a profiledPIDController to have the arm/elevator move to certain setpoints. - Team 5142
Sorry, our repo is currently private.
But here is the LowerArm subsystem and the setpoint command.
Please excuse the mess… :slight_smile: We tend to break a few “OO rules”.
Subsystem
package frc.robot.subsystems.Arm;
import edu.wpi.first.math.MathUtil;
import edu.wpi.first.math.controller.ArmFeedforward;
import edu.wpi.first.math.controller.ProfiledPIDController;
import edu.wpi.first.math.trajectory.TrapezoidProfile;
import edu.wpi.first.math.trajectory.TrapezoidProfile.State;
import edu.wpi.first.networktables.GenericEntry;
import edu.wpi.first.networktables.NetworkTableEntry;
import edu.wpi.first.wpilibj.DataLogManager;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.shuffleboard.BuiltInLayouts;
import edu.wpi.first.wpilibj.shuffleboard.BuiltInWidgets;
import edu.wpi.first.wpilibj.shuffleboard.ShuffleboardLayout;
import edu.wpi.first.wpilibj2.command.Command;
import edu.wpi.first.wpilibj2.command.CommandBase;
import edu.wpi.first.wpilibj2.command.Commands;
import edu.wpi.first.wpilibj2.command.FunctionalCommand;
import edu.wpi.first.wpilibj2.command.InstantCommand;
import edu.wpi.first.wpilibj2.command.ProfiledPIDSubsystem;
import frc.robot.RobotContainer;
import java.util.Map;
import com.ctre.phoenix.ErrorCode;
import com.ctre.phoenix.sensors.CANCoderConfiguration;
import com.ctre.phoenix.sensors.CANCoderFaults;
import com.ctre.phoenix.sensors.CANCoderStatusFrame;
import com.ctre.phoenix.sensors.SensorInitializationStrategy;
import com.ctre.phoenix.sensors.SensorTimeBase;
import com.ctre.phoenix.sensors.WPI_CANCoder;
import com.revrobotics.CANSparkMax;
import com.revrobotics.CANSparkMaxLowLevel.MotorType;
/** A robot arm subsystem that moves with a motion profile. */
public class LowerArm extends ProfiledPIDSubsystem {
  private GenericEntry m_nt_angle_goal;
  private GenericEntry m_nt_angle_goal_test;
  private GenericEntry m_nt_angle_actual;
  private GenericEntry m_nt_volts;
  private GenericEntry m_nt_feed_forward;
  private Boolean m_testMode = false;
  private final CANSparkMax m_motor = new CANSparkMax(Constants.kMotorPort, MotorType.kBrushless);
  private final WPI_CANCoder m_encoder = new WPI_CANCoder(Constants.kEncoderPort);
  private final ArmFeedforward m_feedforward = new ArmFeedforward(
      Constants.kSVolts, Constants.kGVolts,
      Constants.kVVoltSecondPerRad, Constants.kAVoltSecondSquaredPerRad);
  private final Joystick m_joy = new Joystick(5);
  /** Create a new ArmSubsystem. */
  public LowerArm() {
    super(
        new ProfiledPIDController(
            Constants.kP,
            0,
            0,
            new TrapezoidProfile.Constraints(
                Constants.kMaxVelocityRadPerSecond,
                Constants.kMaxAccelerationRadPerSecSquared)),
        0);
    // do all of the CANCoder initialization stuff
    CANCoderConfiguration config = new CANCoderConfiguration();
    // set units of the CANCoder to radians, with velocity being radians per second
    config.sensorCoefficient = 2 * Math.PI / 4096.0;
    config.unitString = "rad";
    config.sensorTimeBase = SensorTimeBase.PerSecond;
    config.initializationStrategy = SensorInitializationStrategy.BootToAbsolutePosition;
    config.sensorDirection = true;
    ErrorCode e = m_encoder.configAllSettings(config, 500);
    // Start arm at rest in neutral position
    setGoal(m_encoder.getPosition());
    System.out.println("Lower Arm Encoder Error Code: " + e);
    System.out.println("Lower Arm Position: " + m_encoder.getPosition()); // prints the position of the CANCoder
    System.out.println("Lower Arm absolute Position: " + m_encoder.getAbsolutePosition());
    ErrorCode error = m_encoder.getLastError(); // gets the last error generated by the CANCoder
    CANCoderFaults faults = new CANCoderFaults();
    ErrorCode faultsError = m_encoder.getFaults(faults); // fills faults with the current CANCoder faults; returns the
                                                         // last error generated
    m_encoder.setStatusFramePeriod(CANCoderStatusFrame.SensorData, 10); // changes the period of the sensor data frame
        // to 10ms
    // do all of the SparkMax initialization stuff
    m_motor.setInverted(true);
    this.setName("Lower Arm");
  private Timer m_testTimer = new Timer();
  private double m_testStartRad = 0.0;
  private double m_testVolts = 0.0;
  private State m_lastSetPoint = new State(0, 0);
  public void kVTestStart(double volts) {
    this.disable();
    m_testVolts = volts;
    m_testStartRad = m_encoder.getPosition();
    m_testTimer.reset();
    m_testTimer.start();
    m_motor.setVoltage(m_testVolts);
  public void kVTestStop() {
    double testEndRad = m_encoder.getPosition();
    m_motor.setVoltage(0);
    m_testTimer.stop();
    double kV = (m_testTimer.get() * m_testVolts) / Math.abs(m_testStartRad - testEndRad);
    System.out.println("!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!");
    System.out.println("Start Rad: " + m_testStartRad);
    System.out.println("End Rad: " + testEndRad);
    System.out.println("Time: " + m_testTimer.get());
    System.out.println("Volts: " + m_testVolts);
    System.out.println("kV: " + kV);
  @Override
  public void enable() {
    // do super enable
    super.enable();
    // now do redo reset with the last set point
    // super.getController().reset(m_lastSetPoint);
  @Override
  public void useOutput(double output, TrapezoidProfile.State setpoint) {
    // save last setpoint to blend set points together
    m_lastSetPoint = setpoint;
    // Calculate the feedforward from the sepoint
    // need to use lowerarm setpoint along with lower arm set point
    double s = setpoint.position + RobotContainer.m_upperArm.getMeasurement();
    double feedforward = m_feedforward.calculate(s, setpoint.velocity);
    // feedforward = 0;
    // Add the feedforward to the PID output to get the motor output
    double volts = MathUtil.clamp(output + feedforward, -6.0, 6.0);
    m_nt_feed_forward.setDouble(feedforward);
    m_motor.setVoltage(volts);
    m_nt_volts.setDouble(volts);
    // DataLogManager.log("LA V: " + volts + " output: " + output + " FF: " +
    // feedforward + " Measurement: "
    // + getMeasurement() + " Goal: "
    // + this.m_controller.getGoal().position + " s: " + s);
  @Override
  public double getMeasurement() {
    return m_encoder.getPosition() + Constants.kArmOffsetRads;
  public void periodic() {
    super.periodic();
    SmartDashboard.putNumber("Lower Arm Goal", this.m_controller.getGoal().position);
    SmartDashboard.putNumber("Lower Arm Encoder", m_encoder.getPosition() + Constants.kArmOffsetRads);
    m_nt_angle_goal.setDouble((Math.toDegrees(this.m_controller.getGoal().position)));
    m_nt_angle_actual.setDouble(Math.toDegrees(m_encoder.getPosition() + Constants.kArmOffsetRads));
    if (m_testMode) {
      double goal = m_nt_angle_goal_test.getDouble(0.0);
      goal = Math.toRadians(goal);
      this.setGoal(goal);
      System.out.println("Upper Arm Test Radians: " + goal);
      m_testMode = false;
      this.enable();
  public void createShuffleBoardTab() {
    m_nt_angle_goal_test = RobotContainer.m_armTab.add("L-Arm Test deg", 0)
        .withWidget(BuiltInWidgets.kNumberSlider)
        .withSize(4, 1)
        .withPosition(4, 0).withProperties(Map.of("min", -160, "max", 160)).getEntry();
    m_nt_angle_goal = RobotContainer.m_armTab.add("L Arm Goal deg", 0)
        .withSize(1, 1)
        .withPosition(6, 1).getEntry();
    m_nt_angle_actual = RobotContainer.m_armTab.add("L Arm Actual deg", 0)
        .withSize(1, 1)
        .withPosition(4, 1).getEntry();
    m_nt_volts = RobotContainer.m_armTab.add("L Arm Volts", 0)
        .withSize(1, 1)
        .withPosition(5, 1).getEntry();
    m_nt_feed_forward = RobotContainer.m_armTab.add("L Arm FF V", 0)
        .withSize(1, 1)
        .withPosition(5, 2).getEntry();
    ShuffleboardLayout pidLayout = RobotContainer.m_armTab.getLayout("Lower Arm", BuiltInLayouts.kList)
        .withSize(2, 3)
        .withPosition(4, 3)
        .withProperties(Map.of("Label position", "HIDDEN"));
    pidLayout.add(this.getController());
    CommandBase cmd = Commands.runOnce(
        () -> m_testMode = true,
        this);
    cmd.setName("L Arm Test");
    RobotContainer.m_armTab.add(cmd)
        .withSize(1, 1)
        .withPosition(7, 1)
    cmd = new FunctionalCommand(() -> this.kVTestStart(2.0), //
        (b) -> this.kVTestStop(), //
          return false;
        .withTimeout(1.0);
    cmd.setName("kV Test 2V, 1.0s");
        .withSize(1, 1)
        .withPosition(7, 2);
    cmd = new FunctionalCommand(() -> this.kVTestStart(3.0), //
          return false;
        .withTimeout(1.0);
    cmd.setName("kV Test 3V, 1.0s");
        .withSize(1, 1)
        .withPosition(7, 3);
    cmd = new FunctionalCommand(() -> this.kVTestStart(4.0), //
          return false;
        .withTimeout(1.0);
    cmd.setName("kV Test 4V, 1.0s");
        .withSize(1, 1)
        .withPosition(7, 4);
  public final class Constants {
    public static final int kMotorPort = 62;
    public static final double kP = 6;
    public static final double kSVolts = 0.01;
    public static final double kGVolts = 0.40;
    public static final double kVVoltSecondPerRad = 3.0;
    public static final double kAVoltSecondSquaredPerRad = 0.1;
    public static final double kMaxVelocityRadPerSecond = 5;
    public static final double kMaxAccelerationRadPerSecSquared = 3;
    public static final int kEncoderPort = 33;
    // The offset of the arm from the horizontal in its neutral position,
    // measured from the horizontal 154.688 degrees to center
    public static final double kArmOffsetRads = 0.61;
// Start Rad: -0.1579997017979622
// End Rad: 0.49854274839162827
// Time: 1.001186999999998
// Volts: 2.0
// kV: 3.0498774289792965
// Start Rad: -0.6565424501895905
// End Rad: -0.026077620685100555
// Time: 1.000199999999997
// Volts: 2.0
// kV: 3.172897053705909
// Start Rad: -0.704095758497715
// End Rad: -0.06442706286907196
// Time: 1.0213899999999994
// Volts: 2.0
// kV: 3.193496905444824
// Start Rad: -0.6227949410676956
// End Rad: 0.8574935272336006
// Time: 1.0200390000000188
// Volts: 4.0
// kV: 2.7563249240752747
Command
package frc.robot.commands.Arm;
public class LowerArmSetPoint extends CommandBase {
  private double m_radians = 0.0;
  private double m_tolerance = 0.0;
  /** Creates a new UpperArm. */
  public LowerArmSetPoint(double radians, double toleranceRadians) {
    // Use addRequirements() here to declare subsystem dependencies.
    this.addRequirements(RobotContainer.m_lowerArm);
    m_radians = radians;
    m_tolerance = toleranceRadians;
  // Called when the command is initially scheduled.
  @Override
  public void initialize() {
    RobotContainer.m_lowerArm.getController().setTolerance(m_tolerance);
    RobotContainer.m_lowerArm.setGoal(m_radians);
    RobotContainer.m_lowerArm.enable();
    DataLogManager.log("LowerArmSetPoint: " + m_radians + " Tolerance: " + m_tolerance);
  // Called every time the scheduler runs while the command is scheduled.
  @Override
  public void execute() {
  // Called once the command ends or is interrupted.
  @Override
  public void end(boolean interrupted) {
  // Returns true when the command should end.
  @Override
  public boolean isFinished() {
    return RobotContainer.m_lowerArm.getController().atGoal();
