Ok… Just started modding my xbox, and I want to put a window in the lower lefthand portion of the “X”. I also want to remove the top of the DVD-Drive so i am able to create this effect…http://www.xb-t.com/gallery/details.php?image_id=3190
…The colors are off because I want it to be Chrome and possibly red. So here is my question… I have a Version 1.6 Xbox with a Samsung DVD-ROM DRIVE Model SDG-605. There is a circular plastic plate that is needed to keep the disc in place and I don’t know if it can be removed from the metal casing. I know that you can do this with the Thompson DVD-ROM DRIVE, but I’m unsure if it will work with this one…
Second question… I am also planning on placing LEDs in the controller ports, under the “XBOX” Jewel, In the fan, and possible some cold cathodes underneath the system itself. If all of the LEDs are 4-pin Female connections, (omitting the Controller port LEDs ) then can i just plug it all into the back of my HDD? Also… Will heat be an issue? If so, where at?
i can’t help with any of that tech stuff, but i would say that the paint looks like…crap. not the colors, thats cool, but it looks like it was spray painted…poorly. if you are going to paint it please please please try and have it painted at a body shop with real paints…you’ll thank me.
So i ended up painting my friend’s Box first… hehe. And actually… it turned out great! I am going to put some pictures up but i need to take them first.
If your going to do any sort of xbox Modifications you should first check into www.xbox-scene.com it has anyort of info you could possibly want for modifying your xbox. the forums are a great place for experienced people to help you out and they have multiple step by step tutorials. This site can teach you anything about soft modding or hardware modding your xbox. Though if you are modding your xbox to cheat well then you should not go there. You would be banned imeadiately upon mentioning anything like that. But If you are modding it just simply to make it better than it is have at it.
again for anyone else that happens to find this thread that needs help modding their xbox go to www.xbox-scene.com
