Xbox Controller - How select right or left hand? - C++
Hello All,
I have been trying to use the Xbox Controller codes. I can’t to find the correct command to pick between left or right hand (klefthand or krighthand).
What am I supposed to put in the blank area below?
if(m_XboxDriverOne.GetBumperPressed(___________) == 1)
{m_LaunchMotorPower = m_LaunchMotorPower + .1;}
what do you mean by right or left hand?
In Java, that method takes a value of type Hand which is an enumeration with kLeft and kRight values (in GenericHID.java). I am not sure, but it looks like you might be using C++ in which case it take a value of type JoystickHand which is an enumeration with kLeftHand and kRightHand values (in GenericHID.h).
In either case, read the documentation for GetBumper and GetBumperPressed to understand the difference. I have seen several people use GetBumperPressed when they really wanted GetBumper.
There is a generic object “Hand” so you could call Hand.kLeft and Hand.kRight. At least this is how I did it last year.
Left side or right side of the controller
I just tried that. I VS code says the identifier “hand” is undefined.
I am using C++. I want to use both GetBumper and GetBumperPressed. I just can’t seem pick left or right.
What goes in the parenthesis for left and right? .GetBumper(?)?
It has been a while since I wrote C++, but either JoystickHand.kLeftHand or JoystickHand.kRightHand. You will need to import GenericHID.h.
I just tried the joystickHand.kLeftHand. Did not work.
Here is what i’m looking at:
Did you import GenericHID.h?
Yes
Try GenericHID.JoystickHand.kLeftHand.
May want to find someone that has done C++ more recently than I, but that may do it.
Didn’t work. Thanks for trying
I have a way around it. I just want to use the xbox controller code.
we do this using this command
if(Driver.GetBumper(frc::XboxController::kRightHand) ==1)
Driver is the name of our Xbox Controller.
Thanks for stepping in. My last major foray into C++ was pre-namespaces. This solution makes sense since XBoxContoller has GenericHID as its base class (look, I said base class instead saying extends).
I’ll try that code when I’m back in the shop. Thank you
