I’m wondering how I can unregister services from XP. For instance, I had Darwin Streaming Server installed at one point, but then I got rid of it. Unfortunately, it didn’t have an installer, so the service is still in the “Services” list.
Anyone have a freeware program to get rid of this sort of thing? I’m not going to try to directly edit the registry (unless you have very specific directions…)
Not sure if you would want this in here or somewhere else. Sorry if you don’t like it.
What I’m really looking for is something to completely remove them from the list, not just disable them. I’m not sure if such a thing even exists, but it’s worth a try.
If you know the name of the .dll, then try opening a command line and use the command “regsvr32 your.dll /u” . I think that unregisters a .dll from the services.
Actually, scotty will allow you to do that. Just use delete instead of the disable button. I’ve done it millions of times.
If you still can’t figure it out, use the “run” command and run “msconfig” without the “”. Then, go over to the startup tab, and find the things you dont want and delete them. That works too.
