XP System Restore
Is there a way to free up space used by it (w/o turning it off)?
Also, is anyone’s internet all screwy right now? Like, if you use MSN/Windows Messenger, can you change your name, or away status?
Because aperantly Wide Open West DSL hates me << cries >>
Turn it off and then turn it back on - it should delete all ur restore points once you turn it off… so once you turn it back on, create another restore point :slight_smile:
*Originally posted by monsieurcoffee *
**Turn it off and then turn it back on - it should delete all ur restore points once you turn it off… so once you turn it back on, create another restore point :slight_smile: **
Yup, thanks :wink:
I did that after posting this (mainly from boredom).
I don’t know if it helps, but I can change my online status right now. (msn messanger) I don’t use MSN though.
*Originally posted by robot180 *
**I don’t know if it helps, but I can change my online status right now. (msn messanger) I don’t use MSN though. **
It was just my internet (because they put a blocker on the ports that the MSBlaster worm attacks…ARGH!
