Hi my team and i trying to set the yagsl swerve code. We use yagsl exapmple code and just change the deploy json file for configuration. Build is succesfull but on drive station we have some errors and it says “No Robot Code” and this error. I cannot figure it out where is the problem. i need some help.
********** Robot program starting **********
NT: Listening on NT3 port 1735, NT4 port 5810
“conversionFactors”: {
“angle”: {“factor”: 28.125 },
“drive”: {“factor”: 0.047286787200699704 }
ERROR 1 Unhandled exception: com.fasterxml.jackson.databind.exc.MismatchedInputException: Cannot deserialize value of type double
from Object value (token JsonToken.START_OBJECT
at [Source: (File); line: 3, column: 14] (through reference chain: swervelib.parser.json.PhysicalPropertiesJson[“conversionFactor”]->swervelib.parser.json.MotorConfigDouble[“drive”]) com.fasterxml.jackson.databind.exc.MismatchedInputException.from(MismatchedInputException.java:59)
Error at com.fasterxml.jackson.databind.exc.MismatchedInputException.from(MismatchedInputException.java:59): Unhandled exception: com.fasterxml.jackson.databind.exc.MismatchedInputException: Cannot deserialize value of type double
at com.fasterxml.jackson.databind.DeserializationContext.reportInputMismatch(DeserializationContext.java:1752)
at com.fasterxml.jackson.databind.DeserializationContext.handleUnexpectedToken(DeserializationContext.java:1526)
at com.fasterxml.jackson.databind.DeserializationContext.handleUnexpectedToken(DeserializationContext.java:1431)
Warning 1 The robot program quit unexpectedly. This is usually due to a code error.
The above stacktrace can help determine where the error occurred.
See Reading Stacktraces — FIRST Robotics Competition documentation for more information. edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:379)
at com.fasterxml.jackson.databind.DeserializationContext.extractScalarFromObject(DeserializationContext.java:943)
at com.fasterxml.jackson.databind.deser.std.StdDeserializer._parseDoublePrimitive(StdDeserializer.java:1139)
ERROR 1 The startCompetition() method (or methods called by it) should have handled the exception above. edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:386)
at com.fasterxml.jackson.databind.deser.std.NumberDeserializers$DoubleDeserializer.deserialize(NumberDeserializers.java:682)
at com.fasterxml.jackson.databind.deser.std.NumberDeserializers$DoubleDeserializer.deserialize(NumberDeserializers.java:663)
at com.fasterxml.jackson.databind.deser.impl.FieldProperty.deserializeAndSet(FieldProperty.java:138)
at com.fasterxml.jackson.databind.deser.BeanDeserializer.vanillaDeserialize(BeanDeserializer.java:314)
at com.fasterxml.jackson.databind.deser.BeanDeserializer.deserialize(BeanDeserializer.java:177)
at com.fasterxml.jackson.databind.deser.DefaultDeserializationContext.readRootValue(DefaultDeserializationContext.java:323)
at com.fasterxml.jackson.databind.ObjectMapper._readMapAndClose(ObjectMapper.java:4825)
at com.fasterxml.jackson.databind.ObjectMapper.readValue(ObjectMapper.java:3637)
at swervelib.parser.SwerveParser.(SwerveParser.java:55)
at frc.robot.subsystems.swervedrive.SwerveSubsystem.(SwerveSubsystem.java:90)
at frc.robot.RobotContainer.(RobotContainer.java:33)
at frc.robot.Robot.robotInit(Robot.java:49)
at edu.wpi.first.wpilibj.TimedRobot.startCompetition(TimedRobot.java:107)
at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:365)
at edu.wpi.first.wpilibj.RobotBase.startRobot(RobotBase.java:453)
at frc.robot.Main.main(Main.java:27)
Warning at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:379): The robot program quit unexpectedly. This is usually due to a code error.
Error at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:386): The startCompetition() method (or methods called by it) should have handled the exception above.
