YAGSL Error (Help!)
I am encountering this error when doing sim on this code. Not much is modified and I just set this up, it happens when enabling:
I can share code/details if needed, but I don’t see how it could be somthing in the implementation. Hopefully somthing simple.
Are you on WPILib beta-2 or 3?
There should be a more detailed error output, could you share it?
Yes. Here is my code.
Beta-2, could that be causing an issue?
Yes
This worked, thank you! I dont have a controller right now but tomorow I will test in sim with one. It enables and that error is no longer there.
