Zones
When climbing the PYRAMID, if you’re hooked on the horizontal bar and your hook touches the vertical bar above the horizontal bar you’re hooked on is that considered being in two levels?
Yes.
OK thank you
Note that for climbing, being in 2 levels and contacting the pyramid in 2 levels are different things. You can be in as many levels as you want (including the floor), but it’s not a valid climb if you contact the pyramid in more than 2 levels (including the floor) or contact non-sequentially (including the floor).
