Our team is remodeling our battery cart.
If anyone has any ideas that can help us out, I’d really appreciate it. :yikes:
We need to store 10 batteries, 3 individual battery chargers and a triple charger.
The space limitations are 26in x 20in x 20in (height x length x width)
If you have any ideas that can help us out, that would be helpful.
Thanks.
Stack all your batteries on one side, 10 tall with the terminals pointing out. Put the single chargers along the side, with lights visible, and cords accessible within reach of the battery shelf. Put the Triple bay charger on its side and mounted in a similar position. You could use Hook-and-loop fastener (Velcro) to adhere the chargers to a wall.
EDIT: actually looking at your dimensions, you may have to do 2 stacks of 5 batteries, placed back to back, with terminals facing away from each other. The chargers could be on one side of the block to have access to both shelves
Rest of your advice is sound, but I wouldn’t advise this. I would advise to either screw or bolt your chargers down. Otherwise, with the constant jostling of a competition and transport, they will come loose and cause havoc.
We build this last year to transport and house our batteries. It holds 10 batteries, 2 triple chargers, bumpers and is a nice shelf for a tool bin. Transport and storage are all built on to a standard hand truck from Home Depot.
20 deep x 20 wide x 36 tall (not including the hand truck).
I don’t have a picture of the final project, but we built one for last year’s competitons based on similar size constraints and info from here.
Ours is 24"x24"x36" when closed, it folds in half and locks together making a rolling box for travelling; each half is 12"x24"x36" with piano hinge, locking clasps, collapsable handles and caster wheels. It holds 8 batteries standing on edge in slots on the bottom with battery chargers on a shelf above (4 at the bottom of each half). A shelf above for some parts, controllers, etc. Complete with wired power strips so all we have to do is “plug it in” and its going.
The attached image is our “rough draft” before we built it, which doesn’t show how we actually built the battery slots and shelves, but you get the idea of folding within itself and locking. One thing we learned, get big enough diameter caster wheels to handle rolling on pavement etc, not all surfaces are smooth floors.
Pneumatic wheels are not a bad idea, except problems with size constraints.
In our example, the footprint of each half 12"x 24" needing a minimum number of wheels limited the size of wheels/base plates that could fit. The bigger the wheels, the further away from the edges the wheels would be. We needed to make sure wheels would be at all 4 corners when closed for rolling when travelling, and enough wheels on the inside edges when opened so it was sturdy.
We went with 8 swivel caster wheels with the 4 outside being “lockable” so when opened up in the pits we could lock the wheels and it stayed opened and didn’t move.
Or, if you want to get complex, spring-load the wheels to a hinged bar below. That will be a shock absorber. However, use only when you know that the conditions will be rough, or if you will be driving solid wheels over a nailbed
Also make sure your chargers have plenty of ventilation or you could have a serious problem. Our battery cary has extra power outlets on it so it doubles as a power strip in the pit, and that is incredibly convenient.
